Hello,
I am busy with bringing the right channel back to life from an old Yamaha pc2002m. It's work in progress and I want to stick to the original components and luckily I found through my job a collegeau from Japan who will get the original 2sc2238b and it's counterpart 2sc968b.
I have the manual as well, the schematics look quite decent, as I've seen this topology before in other amps (also a bit similar to the lfa 150 elektor)
Also built quality is impressive, I guess one of the reasons why 70ties audio is so popular (got a Marantz 2238 on the shelf and monster Mitsubishi..no plastics)
I will be very curious how it sounds, but anyone interested in the manual, let me know.
Haai HaaiFaai,
I am on the lookout for a PC2002M at the moment.
I've used many of these amps before, and I agree that they are quality bits of gear. I think they are one of the best sounding amps Yamaha have ever made and super reliable. You will like what you hear!
I would appreciate it if you could send a copy of the service manual or just schematic in case the need arises one day.
I'm happy to pay for postage etc if it's a paper copy.
Ralph
Ralph
Hello Ralphs99
It's a pdf file, so I can send it to your email address. Currently I've optained the drivers, 2sc2238b and 2sa968b, although only one was broken, will just replace them both. This amp is quite easy serviceable too.
I noticed that this topology was also used in a Stage Accompany amplifier which used to be a state of the art beast in the 80ties.
The previous owner only used one channel and didn't want to invest I guess in repairing it (those output transistors are here in europe between 15-20 euro's each with 8 of them missing) so fo testing I will first use the often used combo mj15025 and mj15025. Will use some big resistors in the power lines before going full monty.
Hi HaaiFaai,
I'd love a PDF please. Send to: bhomester at gmail dot com.
I used to service these. They sounded very good actually. There was a solder connection issue with the sockets for transistors mounted on the heatsink I think. Cracked joints, resolder them even if they look okay.
As I recall they were very clean sounding, very little background noise.
-Chris
-Chris
We've got our own little fan club going on here!
Thanks Haai Faai.
I'm sending you a message with my email address.
Good luck with your repair.
That's smart thinking about putting resistors in series with the mains lead. A tech I worked with once used a couple of light globes to achieve the same effect. Cheap, simple and self protecting.
Ralph.
Thanks Haai Faai.
Ralph.
The resistors are on the plus and minus lines, so in case of erratic behaviour due to wrong voltage/currents of driver/output transistors, the resistors will go up in smoke rather then the transistors themselves ;-)
The amplifier is doing a test run, all parts original except for one 2sa999 which was pin compatible with a bc640 (current limiter circuit). Idle current stays stable and it's running without the test resistors and with the mj15023 and mj15024...the original output transistors will be placed after operation is proven ok.
First impression is a very clean sounding amp..
Yup, cleaner than you would expect from a PA amp.First impression is a very clean sounding amp..
Shouldn't you be using MJ15022 and MJ15023, or MJ15024 and MJ15025 as complimentary pairs for your outputs?
-Chris
Yes I use a complimentary pair, although one pair is rated 250 Volts max, while the other is 200 Volts. (Those I had laying around) So the mj15023 and mj 15024..if this runs fine I will replace them with the 2sc2608 and the 2sa1117 ( 8 in total)
The 2sc2608 and 2sa1117 are both rated for 200 volts, so I have a safe margin when using those Motorola workhorses ;-)
Btw, it's a tip to use the mj series when you do a first test run, as those are rugged and cheaper then the original ones ;-)
Hi HaaiFaai,
Really, you could just leave the Motorola parts in. Why spend the money on expensive parts when you could just stay with the good Motorola parts? If you really wanted to, you could use the newer MJ21193 and MJ21194 pairs.
-Chris
-Chris
Hi Hai Fai,
I had a problem with the email you sent. Could you try a different address please?
ralphss at optusnet.com.au
Ralph
Ralph
I was lucky that a friend of mine lives in Japan, so I have the original Sanken output transistors for a reasonable price.
Next step is to get more lamps working, so I can read a book next to the large VU/Power meters.
Will send it today. Btw perhaps you can help me with something else.
I am still looking for a schematic for the Marantz 2238 receiver as I have an issue with the tone controls (one channel has a bass lift)
I guess it might be some leaky electrolytic capactitor causing more bass lift.
PC2002M schematics
Hello HaaiFaai,
I am in desperate need of the service manual for the Yamaha PC2002m Amp. I would appreciate it if you could e-mail me the pdf that you have.
Gretchen@avatarstudios.net.
Hello HaaiFaai,
PC2002M
Hello,
I am in looking too the the service manual for the Yamaha PC2002m Amp. I would appreciate it if you could e-mail me the pdf that you have.
jcalcantara@yahoo.com
or julysound@gmail.com
Hello,
PC2002M yamaha power amplifier
Hello,
I recently bougth on of this amp for repair and I am looking for the service manual, if anyone have this manual , can you send a copy to my address :
jcalcantara@yahoo.com or
julysound@gmial.com
Thanks you
Hello,
julysound@gmial.com
Thanks you
Re: PC2002M yamaha power amplifier
Click here for the PDF of PC2002M. Perhaps one of the last great Yamaha's. The one's I liked anyway. 😉
Shawn.
djsuro22 said:Hello,
I recently bougth on of this amp for repair and I am looking for the service manual, if anyone have this manual , can you send a copy to my address...
Thanks you
Shawn.
PC 2002m service manual
Thanks you for the link for user manual of this amp, I have downloaded and now I will give you to the technician who is in charge of repairing it. Where can i buy parts for this amp?
Thanks You.
Thanks You.
Hi djsuro22,
What you need are real parts. Your technician should know where to get them. Yamaha would be the obvious first choice. Getting guaranteed Japanese semiconductors is not easy, so if you don't already know where .... One hint. Do not buy from the cheapest source!!!
Consider too, the bigger the amp, the less likely a fake is going to survive. The more power you have, the more damage is possible. Please tell me your technician services audio professionally and not TVs.
Hey Shawn,
How are you doing lately? Long time, no see.
-Chris
Hey Shawn,
-Chris
- Yamaha pc2002m
