Hi I got a Yamaha DSP-A595 I would like to mod it but I have a few questions.
Its an AV amp but I only use it as a stereo amp, it got a good review for it's AV abilities however its stereo verdict was said to be lacking in the mid range.
I have an anologue signal coming into the amp and would like to change the output op-amp which is a NEC4570c (dip8) to a DIP8 IC Socket Adapter and then roll a few different op-amps, as well as change the 2 power supply Capacitors.
1. Will I run into any problems just changing the main speakers op-amp(and not the other 2 op-amps for center rear fl+fr etc).
2. Any recommended op-amps that will fit and potentially open up the mids?
3.The 2 power supply Capacitors are 8200 56v although the service manual states they should be 6800 56v can i replace these with 8200v 63v and/or 10000 63v in theory?
Many Thx
Many Thx
No, that does not matter.1. Will I run into any problems just changing the main speakers op-amp(and not the other 2 op-amps for center rear fl+fr etc).
This lacking-in-the-midrange is a bit strange, because that is where least problems are to be expected. The usual suspects depend on your budget. The cheapest solution and probably best-bang-for-the-buck is the NE5532A, followed by OPA2134. If you want to invest more, this may be an interesting thread for you.2. Any recommended op-amps that will fit and potentially open up the mids?
You can do that. What do you expect to happen when you replace one 8200 µF capacitor with another?3.The 2 power supply Capacitors are 8200 56v although the service manual states they should be 6800 56v can i replace these with 8200v 63v and/or 10000 63v in theory?
