Hi to all,
and thx for reading this.
I need the schematics of this preamp, do you have them??
If your answer is yes, plz send them to me at gokuadk@inwind.it
Thx again for helpfulness, this site is great!!!
I can help here.
Please tell me what year of manufacture DG Stomp MKI or MKII ?Do you want overlay as well as circuit diagram?
Parts list?
(it is a large file but can be broken down)
...will send thru after your reply....
Parts list?
thx for your reply.
i need everything that you have on this stomp box. simply everything.
but what do you mean with the mki or mkii ??
the serial number of my dg-stomp is HK02379
thx again
thx again
The DG stomp was available as in MKI and MKII versions.
Both schems are different.
I'm the lucky guy who repairs them for customers when the need arises.
OK I will send you thru the file(s)
(It is a bit under 5MB file size in total)
Can I please also have the schematics for the DG Stomp, I'm trying to fix one for a friend.
DG-stomp Buzzing???
i just got a dg stomp from a friend
but it doesnt work
all there is when i connect it is a buzzing sound
how can i fix this, if it can even be fixed?
but it doesnt work
DG Stomp - not usable now - pop/clicks
Had the DG stomp for some years now.
Has been good.
Now - pop/clicks - loud.
Ok for while, then starts up. Then does it all the time.
Making it not usable.
Battery ok.
No obvious issues with case open.
Can you please send the schematic or repair guide (the old - test voltage at these points manual)
Has been good.
Battery ok.
You can find the service manual here:
http://www.yamaha.com/yamahavgn/CDA...CT%26VNM%3DLIVE%26AFLG%3DY%26DTYP%3D,00.html#
Hi.
Is it still possible to get the schematic?
The problem with my stomp box is that it doesn’t show any signs of life. My friend bought it on ebay. After my first turning on several leds were shining and the pedal didn't respond to any button. I put out the battery to check its voltage, it was ok (3.11V), and after this the pedal ceased to show the signs of life. The voltages on chip regulators are ok (+-15V, 5V). Is it possible to update the FW? What should I check next?
- Live Sound
- Instruments and Amps
- Yamaha DG-Stomp schematics????
