I am looking to build a new arrangement into existing pair of gifted cabinets of about 6-8ltrs. I want to run two identical (ideally 4 inch, wideband) drivers on each side in a (polk SDA-esque) crosstalk reduction arrangement. eg; LEFT; R-+, L+-. RIGHT; R+-, L-+ The drivers will be about 8-inches apart, horizontally, in each enclosure.
I have this arrangement set up in my room with 4 separate speakers and I love it. But the logistics of this are cumbersome, to say the least.
I will be running a sub from 100-150hz
I'm posting here simply to get tips and suggestions as I go through adapting the cabinets.
Any recommendations for good and affordable (ideally 4" to approximately fit the current cutouts) wideband drivers, bearing in mind cost of buying 4x
Also, my current set up uses two amps to achieve the "effect". Amp suggestions would also be useful.
I'm not particularly technical in terms of electronics/physics language.
I'm not particularly interested in a debate about the merits of xtc approach. Just hoping for experiences and tips.
