Hi folks!
I found on web lowpass filter like this one, and author says that an little extra coil helps to supress cone breakup region. I wish to know how to calculate that extra coil, that is, to calculate it for known peak frequency of midbass.
Is there any equation for that?
Thanks!
Thanks!
This filter exhibits a notch (zero transmission) at the resonnant frequency of C1L2 :
f = 1/[2*pi*sqr(LC)]
where f is in Hertz (cps) L in Henry and C in Farad.
If the notch is too sharp, add a small resistor in series with C1L2 (which can be the dc resistance of L2, if the wire is small in diameter)
Regards, Pierre Lacombe.
