xls10 vs. something else
nyman said:
I'm planning to build a subwoofer using xls10+2 passive radiators in a 25 litres box. My Question is, are there any other better driver for use in a small box?
I couldn't find one. 🙂
I used one PR, the heavier version of the two. I'm happy with it. I'm using it in a small room. I modified the plate amp to give a little boost at about 22Hz.
XLS 10
I have built 2 boxes using 1 PR and 1 XLS per box and I'm driving them with a Crown K2 power 550wpc/4 ohms .I also use a parametric EQ in order to boost the frequencies below the 40 hz point at which the small boxes tend to drop in efficency.I live in an old second storey house and i'm scared to turn the volume past a certain point where the whole structure starts to rumble.
These are really great drivers. Feed them lots of clean power and they will amaze you. Look for High damping factor power amps to get fast snappy bass.
Happy listening
