Hey, I want to build this preamp here Op-Amp Microphone Preamp
But I'm a total retard on this stuff, how will I connect the XLR input and output into the circuit?
I guess they go in the yellow circle and in the 'Out', but how?
Thanks in advance
Thanks in advance
This is an unbalanced preamp because it connects one end of the microphone to ground. A high quality preamp will have only the shield (XLR pin 1) grounded and a fully differential input stage connected to the microphone leads (XLR pins 2 & 3) in order to get good CMRR and therefore reject most of (common mode) noise induced into the microphone leads.
A little light reading...
Thanks. Did not finish the reading because it's really big 😵 but gonna finish it after lunch..
In the meantime... Do you know any good diy project for a mic pre?
1 channel is ok, no phantom power needed..
What about this one? http://web.archive.org/web/20061214092614/http://1176neve.tripod.com/id10.html
It has phantom power... can I just remove it from the circuit?
