DECKY999 Member Joined 2007 2008-03-11 2:11 am #1 2008-03-11 2:11 am #1 IS there anything wrong in using MKP X2 caps usually used for mains EMI suppression as signal coupling caps in audio? Nordic Member Joined 2005 users.tpg.com.au/users/gerskine/dxamp/ 2008-03-11 8:07 am #2 2008-03-11 8:07 am #2 I have done that with success before... D decky Member Joined 2006 2008-03-11 9:17 am #3 2008-03-11 9:17 am #3 I guess it is only a bit wider tolerance that might be an issue? ashok Member Joined 2002 Paid Member 2008-03-11 12:03 pm #4 2008-03-11 12:03 pm #4 Tolerance shouldn't be an issue unless you are using it to define an exact frequency . As input coupling cap it should be fine. All makes of X2's do not sound the same ! Do some comparative listening tests. If you don't , they will still be OK ! Status Not open for further replies. Share: Facebook X (Twitter) LinkedIn Reddit Pinterest Tumblr WhatsApp Email Link
