x over
Hi guys I want to build a 2 way speaker using the Vifa m18wo 0908 woofers with the Vifa xt25 tg3504 in a wtw array.I was thinking of a sealed box of 35 litres. Can someone suggest a x over that would be suitable. Thanks.😎
It appears that a closed box for this MTM configuration will start rolling of at around 68 Hz and for this size woofer (6.5") you could get better bass from it using a vented design. But there are advantages to using a sealed box however(less complexity for one). Also just wondering how you arrived at a volume of 35 lt.
You can try and download WinISD if you havent already and play around with different volumes and box types first before you dive into xover design. There is no single xover design for a given speaker. Hope I am not adding to the confusion.
prash
