I am not that familiar with x-over filters from Subwoofer, commercial or DIY design. Questions please:
1. What kind of filters do high-quality commercial subwoofer use in their sub, e.g.BW 12db(-3dB at F3) or something else if so what? Please explain.
2. If I build a subwoofer from scratch and use an external DSP filter what kind of filter should I set if my main speakers are sealed? DO I have to phase invert if necessary, how to make sure the phase is correct? BTW I have a measuring instrument, microphone and REW s/w. Please explain.
This would help me to integrate my Sub with the sealed Main speakers.
Thanks to those who can answer my questions?
Lucky you got sealed speakers, because you have to determine the resonance and the Q-factor. This is easily done with an impedance sweep and REW can calculate the resulting Q.
For such a sweep you need a soundcard with stereo line inputs and a precision resistor of say 47 ohms.
Alternately you can run a frequency sweep with your mike very close (5mm) to the diaphragm and compare it with a 2nd order highpass.
Now when you know these 2 data, you can select a second order highpass with the same resonance, the Q factors multiplied should be 0.5
Example you measured 75Hz and Q=0.85, the filter for the mains would be 75Hz and Q=0.588.
You now have a Linkwitz-Riley 4th order high-pass.
The sub doesn't need measurements just insert a 4th order L-R lowpass 75Hz
Thanks, I will come back if I have more questions when I am testing the speakers.
