WTB: STK043 stereo amplifier chip
The price of them is astronomical!
Personally, I'd see about retrofitting some small amp circuit in there. Something with TIP142/147 darlingtons for example.
There might also be other kinds of STK that you can use that are pin compatible, more readily available and cheaper.
i agree too
the price for a thing like that is very expensive ( on the other hand i dont like stk sound any way)
..... depainting on the rail voltage i would be very happy to locate inside a couple of very happily P3A borads ....
you may wana check this on esp pages .....
Actually now I come to think about it, what I would do is retrofit some LM3886s into it. They are small compared to the STK and you could probably do a point-to-point wiring if you don't feel like doing a small PCB.
Also, they will sound better - the STK-043 datasheet says 20W output power into an 8 ohm load at 1KHz has a THD of 0.4%! The LM3886 is far superior in this regard.
