WTB: RTR-DR1 bass drivers or specs for same.
I own a pair of these speakers, but they're missing the original two 10" horizontally firing drivers, as well as the down firing 12".
Original wiring is there and (luckily) the circular electrostatic panels work fine. The bass drivers were all replaced in the past with some lovely (?) Dai-Ichi items. Actually not as basd as you might think. But I'd certainly like to track down a set of the originals, if anyone has any suggestions ?
Failing that, I'd also greatly appreciate any help in finding the Specs for the original drivers. Apparently, they were all wired together in parallel, without any crossover at all? Hence the need to find out as much about the drivers as possible, so I can try and find something that matches if the originals aren't obtainable.
Any help would be great, and/or comments from previous owners if you like.
Cheers
Scott
