I'm looking to buy a woofer from the original Time Window. This is the 6" driver with the round (not octagonal) frame and paper cone. Model number is 4846SD. Thanks!
Measure the dcr of its mate. There were variations in production, and the crossover was adjusted to suit.
Also, foam or rubber surround originally?
I have a few, when you have info, I will check.
Assuming I'm measuring it correctly (disconnect driver from crossover, measure resistance from terminal lug to terminal lug), the DCR is 7.3 ohms. The surrounds are butyl rubber. Thanks for the reply!
