I have found some wrong specs on mauser.ca …. My understanding is that if:
Supply Type: Dual
Maximum Dual Supply Voltage: Y
Minimum Dual Supply Voltage: X
then: Operating Supply Voltage: 2*X - 2*Y
Example: OPA604
Supply Type: Dual
Maximum Dual Supply Voltage: +/- 24 V
Minimum Dual Supply Voltage: +/- 4.5 V
Operating Supply Voltage: 9 V to 48 V
Most opamps have the correct specs like this example.
But Here are two examples where the Specs are wrong:
AD8597
Maximum Dual Supply Voltage: 36 V (V- to V+?)
Minimum Dual Supply Voltage: 10 V (V- to V+?)
Operating Supply Voltage: 15 V ?????
AD797
Supply Type: Dual
Maximum Dual Supply Voltage: +/- 18 V
Minimum Dual Supply Voltage: +/- 5V
Operating Supply Voltage: 5 V to 18 V (should be +/- 5 to +/- 18 ??)
Is it me or are the specs inconsistent on mouser.ca ?
Supply Type: Dual
Example: OPA604
Supply Type: Dual
AD8597
AD797
Supply Type: Dual
Yes, these should be listed in a more clear and consistent manner. For example:
Single supply use: 5V to 36V
Dual supply use: +/- 2.5V to +/- 18V
