Wrap-around veneering
I am about to veneer a 42" high speaker and would like to use one continuous piece to wrap completely around the speaker. I have 3/4" roundovers on the vertical edges. How does one get a clean looking seam on the back where the two edges meet?
Gabe
Thanks, Dan. I guess my concern is cutting the veneer at just the right size and not leaving a gap or having it overlap. I also don't want to have the overlapping veneer stick onto itself. Will a metal straight edge held close to the seam allow me to get an accurate cut? Maybe I'm just being overly cautious.
Gabe
Cutting Veneer
Your best bet is to place a 1/4" spacer on the back and over cut the veneer. Then sand it to fit. If your good with a block plane and it is sharp you could plane it close. You can also scrape it to fit if you are within a 1/16th or so.
IF THIS IS YOUR FIRST TIME DOING THIS THEN OVER CUT IT AND SAND IT TO FIT. IT's NEARLY FOOL PROOF.
Mark
Re: Cutting Veneer
Mark
I'm having a tough time picturing the technique described here. Can anyone elaborate or Illustrate?
Hagbard said:
I found this site which contains excerpts/screenshots from the above mentioned video. It's helpful to see an example.
http://www.woodshopdemos.com/vac4.htm
Hey that's John Lucas's site! If the site isn't clear, he posts and reads pretty regularly over on theoak.com a woodworking board I read regularly. He's a nice guy and is willing to answer lots of questions. (Not to mention the other people on the site as well)
