WR.30 speaker kit build kit price is $480.00 plus the cost of the Parts Express cabinets I used the curved Piano black for this build.
CSS WR.30U7
WR.30 MTM Loudspeaker kit with upgraded caps, resistors, wire, damping pads and acoustic foam (Pair)
These kits use the WR125STR drivers with XBL plus the Wavecor TW030WA01 tweeter and are designed around the use of the Parts Express .50cf cabinets. If you build your own cabinets you could order the pre-finished PE grills. This kit adds Obbligato 630v caps, Duelund resistors, DH Labs Odyssey 14 gauge OFHC copper wire, acoustic foam and damping pads.
Upgraded crossovers assembled ready for wiring
DH labs wire used for the internal wiring for the crossovers
DH labs wire cut to size ready for connectors
DH labs wires with connectors installed ready for connection to crossover boards.
Crossover boards with DH labs ready for assembly
WR.30 crossovers wired ready for installation into cabinets
WR.30 speakers mounted to the CNC pre cut baffles ready for assembly.
Install damper pads with heat gun to activate the glue.
WR.30 crossovers installed with acoustic foam also installed
Wired up drivers lowering the front onto the cabinet
For this set I decided to change the front color of the baffle to a silver metal just a quick spray on in minutes nothing fancy.
Breaking the WR.30 speakers in.
The mess TL 3 way CSS, plus the MLTL is the VX.2 crossover parts on the sub box is for the 3way.....
