Working on BOM for 24ch amp to use with active line array
Hi Solid State-
Starting to search for parts to assemble a 24ch amplifier.
I'm not an EE but I've worked with class D boards on other projects, and made a few PCB for my LED projects.
I was hoping to either find and upgrade or build my own like the attached TDA7377 board: low BOM count, mostly thru hole parts. Use +-DC.
I'm a pretty good scavenger/bargain hunter so I have the drivers, DSP box, a 24x9x2" heavy heatsink, and Meanwell SMPS in 24v and 48v x 700W that have been getting dusty on my shelves.
All that said, here's what i'm after:
-Your favorite solid state amplifier chip for a low power build?
and
-Are there issues with arranging parts in parallel on the same power supply? for example - I had to set Master/Slave on tpa3118 boards to use them in parallel on a single power supply.
Just feeling things out. Any tips/ideas are appreciated. Thanks.
