Has anyone else seen Mr. Bohlender's new woofer for his in-wall speakers? He showed me a sample at the CES convention and I was highly impressed. It is about 4" wide and 18" long with a big flat diaphragm. The voice coil is nearly the same size as the diaphragm so it gets driven over its whole surface. Kind of like a track field shape. I believe the magnets are neo and the frame is super chunky, like a boat anchor plus a big Xmax. He says it has a pretty high Q so I started to salivate at the possiblity of some dipoles with these..... Maybe it will work really well and someone will do a similar version for us all to enjoy.
Greg
Greg
How do you figure?The voice coil is nearly the same size as the diaphragm so it gets driven over its whole surface
How do I figure?
Well, as oppossed to say a 6*9 driver that has a 1" vioce coil, I would say that a driver that has a coil that is nearly 2" by 12" qualifies, wouldn't you? This is the set-up that Wisdom is using for its new inwall woofers.
Greg
Greg
I find it hard to qualify the statement that a diaphragm is driven over its whole surface when that diaphragm is moved by ANY kind of voice coil. Are you trying to say that a larger voice coil couples better than a small one? Fine, I can accept that. But saying that a voice coil that does NOT directly apply a force over the entire diaphragm DOES, slightly irks me.
OK, fine, I see your point....it's NOT the ENTIRE suface, but come on. You KNEW what I meant right? I mean, if i mention a voice coil at all, we know that it is driven only at the point where it attaches to the cone, so why the big deal? Sorry I didn't say, "driven over a large percentage of it surface"
greg
greg
And that isn't quite precise, either. If the voice coil is nearly the same size as the diaphragm, then it's kind of like a huge dome, and the middle will be prone to resonance (I think).
454Casull said:And that isn't quite precise, either. If the voice coil is nearly the same size as the diaphragm, then it's kind of like a huge dome, and the middle will be prone to resonance (I think).
a quick look at it shows that a cone nominally supported/driven at one central point will be extremely prone to resonances...
a stiff flat surface driven along the periphery will have a far better chance of not having as many break up resonances...
at least that's imho...
_-_-bear
- Planars & Exotics
- Wisdom Audio's new woofers
