Wiring up an ALPS RK27 50K Potentiometer
Can someone please confirm the pinouts on an ALPS RK27 pot. I have never used one before. You would think it would be the easiest thing in the world to google but I am having trouble.
Is 3 an input, 2 the wiper (or output) and 1 a ground?
If so, do I connect the coax shield to 1 then tie them together?
Or, I have read elsewhere that people connect the coax shield at the input connector end and then leave it open at the other end?
Anyone have experience with these pots?
Thanks guys, I think I was (am) getting confused because you have a coax coming in with left and right channels and a shield - the left and right go to pin 3 of each resistor but you are left with choosing a side for the one shield to go to (on pin 1)? Same with the output side to the amp.
