Wiring secondaries of two power trafo's in parallel?
Hello,
Am I right to think that parallelling the secondary ht windings of two identical power transformers (primaries also parallelled with respect to phase) will result in: same voltage as one trafo; current rating doubles; internal resistance is half of one trafo?
Are there any electrical drawbacks to this approach?
I could also go dual mono but the parallelled approach (if my suppositions are true that is) fits better for the amp I'm planning + needs less filter components...
Thanks🙂
Still not guaranteed. If one transformer outputs 40V, the other 39.9 V, and the secondary resistance is 0.2 ohms, then you have 0.5 amps flowing from the higher voltage one to the lower. Also the output voltage can change under load because primary and core losses might be different for the two as well, so you're really looking at a suboptimal situation.
I'd recommend dual mono. You'll feel virtuous doing it, too.
Francois.
Back to dual mono than! And this time right ... my previous amps were meant to be dual mono but I accidently parallelled power trafo's on both occasions... strangely enough one plays perfectly while the other one almost burned both it's trafo's - ...:xeye:... I did experience the virtuous-feeling thing however😀
