Wiring for open baffle
Hopefully this is the right area but if not feel free to move it. Each of these baffles has four 4ohm drivers wired series parallel for a 4ohm load per side. Is it okay to then wire them both together in series for an 8ohm total load to connect to a single plate amp? I'm a bit new so want to be sure. Thanks!
Chris
With four 4 ohm drivers per side you can only get 16 or 4 ohms or 1 ohm! Unfortunately, 8 ohms is not do able.
Each baffle is wired series parallel at 4ohms. What I did was connect positive of one baffle to negative of the other baffle and then positive and negative from each to the amp. Essentially the same I assumed as connecting two single 4ohm speakers in series for an 8 ohm load. I hope that's clear enough.
To be clear, four 4R drivers in series-parallel is 4R.
Two 4R speakers in series is 8R.
The answer is yes.
As you can see, others are confused on this, as well.
And as always, observe proper phasing.
Thanks so much! It confused me for a bit but then it occurred to me to consider each speaker set as one unit. So regardless of the numbers of drivers I should deal with each as I would two single 4ohm drivers that I wanted to connect to an amp.
Chris
Yes
Reactions: Chris Osborne
It seems easy to achieve...
He already has each panel wired series parallel. Now he just want to put two panels in series.
You were able to sum that up so much better then I did! Haha
They're connected to the amp now and working wonderfully. I'm very pleasantly surprised at the amount of bass these are able to produce. Being both OB and 6.5" drivers. They sound wonderful! Now to get my mid-bass/mids sorted. I have to run the crossover for the subs all the way up at 160hz or there's a frequency gap and the Tang Band mid drivers just seem too pushed running "full range" without the crossover. Going to try some 8" drivers I have for the missing mid-bass frequencies. I need a frequency measuring setup. One thing at a time I guess. 😉
Chris
