Wiring a bass cab
Not sure if this belongs here but here it is anyway. I'm wanting to build a bass cab containing a 1x15, a 1x10 and a 1x6. The 1x15 is 200W the 1x10 is 150W and the 1x6 is 100W. I'm going to run a 300w head through it. First off is it possible to even make this cab with these speakers? Second, how would I wire it? In series or parrallel and which should I wire to first if it matters. Will I need anything else like a compressor or crossover?
Also need to ask about impedence, what impedence would each speaker need to be to make this work. Does the way its wired effect impedence? I think all of the speakers are 8ohms if that helps.
Thanks in advance,
Freddie
