I am using a 12au7 in a preamp and I have questions about wiring it to the 6.3volt supply. I have heard that you can use a 12au7 on a 6.3volt supply somewhere but I cant figure it out. Unfortunatly I only have one 6.3volt winding on my transformer so I may be out of luck. Can anyone tell me how to do this?
Milo
Milo
Tie pins 4 & 5 together, connect 6.3V across pins 4+5 and 9. Just connecting both halves in parallel.
Tim
Tim
Sweet. Thank you very much. I had thought for a moment that I had screwed the pooch big time.
Milo
Milo
Hang on. Isn't that the way you would wire any tube that takes 6.3V to a 6.3V supply (Ie a 6Dj8)? The 12Au7 is a 12.6V tube though.
I am sorry if I'm beting an idiot, Im still getting the hang of this stuff.
Thanks for your help.
Milo
Milo
Milo, no, you hook up a 6DJ8 by running 6.3 v between pins 4 and 5. They're not tied together in that case. Pin 9 in that family isn't a heater center-tap, it's usually a shield.
So what should I do with the 9pin on a 6DJ8 tube? leave it alone or ground it? Thanks for your help, I really appreciate it.
Milo
Milo
Sch3mat1c said:Tie pins 4 & 5 together, connect 6.3V across pins 4+5 and 9. Just connecting both halves in parallel.
Tim
How about connecting both halves in parallel if you have 6.3V Center Tapped (3.25-0-3.25)? Where do you think i can connect Pin 9?
Thanks....
pin 9?
s2Kov,
Like this.
Wayne
s2Kov,
Like this.
Wayne
Thanks....
Thanks wayne....
Heater Current
Guys,
In addition to my previous question, assuming i use to two (2) 12au7 and both halves connected in parallel. What is the required current for the transformer? Is it 0.6A for two twin triode?
Thanks....
Guys,
Thanks....
- Tubes / Valves
- Wiring a 12au7
