Windows Oscilloscope signal voltage input
Would I damage the soundcard with a 40v rms output from the amp when connected to the mic in ?
Who knows? Try it and let us know 🙂
Even if it doesn't get damaged the input will clip at few hundred mV and you won't be able to measure nothing above that. Is it not obvious that you need an input attenuator?
40volts into the mic-in ? :yikes:
You really shouldn't use mic-in, these are typically very poor, use at
least the line-in, and use a voltagedivider like 47k+1k to reduce the
level down to ~1v rms. Be careful to not exchange cables with
grounding, you might fry your computer and/or amp !
I haven't tried this particular software, but using a pc as scope is
quite good to observe waveforms and do some fundemental thd
measurings...
But it can't replace a real scope to verify stability.
Mike
40V will smoke a sound card.
I built an external box to act as a buffer/attenuator. It's just a unity-gain buffer (I used a BUF03) with a switchable 10:1 attenuator and an input impedance resembling a scope (1Mohm in parallel with 20pF). In conjunction with a couple of scope probes (a 1x and 10x), I can switch between no attenuation, 10:1 and 100:1.
The sound card route will not really do most of the things you'd want a scope to do because of the very limited bandwidth; it's good for things like spectral analysis, but terrible for troubleshooting or looking at square waves or impulses. A decent used scope can be had for perhaps $200 and should be considered an essential tool. Doing electronics without a good scope is like working on a car without using wrenches.
Sooo right. If you don't use a wrench, I guess you are using a hammer.
I measured the input impedance of my SB Live! 24 bit card on line in and got around 8K8. I will retest to make sure as I used a Shallcross decade resistance box and looped line out to line in and used RMAA to show -6dB. I don't know how much it's own output would be loaded down because this computer is no where near my bench.
-Chris
