Hi There,
Will the Amp Camp Kit suit a pair of KEF 104AB reference speakers
Specification: Model 104aB
System type: Two-way, stand-mount
Enclosure type: Passive radiator
Size: 630 x 330 x 260 mm (24.8 x 13 x 10.23 inches)
Weight: 16.3kg (36 lb)
Input Impedance: 8 ohms
Rated maximum power: 100W programme
Amplifier Requirements: 15-100 watts per channel into 8 ohms
System resonance: 35Hz, mechanical reflex
Frequency range: 30-30,000Hz
Frequency response: 50-20,000Hz +/-2dB
Sensitivity: 12.5 watts for 96dB at 1m and 400Hz in anechoic conditions
Crossover Frequency: 3000Hz
Finishes: Walnut, Teak
Grille: black microcellular foam
System: SP1038
Drive units: B200 bass unit (SP1039), BD139 passive radiator (SP1042), T27 tweeter (SP1032)
Crossover: SP1065
System: SP1038
Crossover: SP1065
