Wiim PRO filtered PSU
Wiim Pro power supply (can be used for anything that has same requirements, just make sure you don't go above 3A), USB type C and aux pads for DC barrel. Also led pads for pilot light (marked with a dot for anode, not seen in pictures but its on gerber). Based on AmyAlice , but modified to be a separate psu on it's own. It uses Mean Well IRM-20-5 smps can be used with others of the same footprint, and two connectors with pitch of 5mm (or solder directly preferably). Rest is the same BOM as og. Already built and tested as seen below. As good as it gets regarding smps supplies.
Enjoy.
  • Wiim Pro filtered psu.zip
