Hello,
Using a serial audio source (i2s, I believe, but could be wrong) connected to a DIT4096 with a 12.2880MHz clock (256*Fs, which is 48kHz) which is connected to an S/PDIF transmitter to my DAC. When I turn on the source (nintendo gamecube) I only get one channel (left) and the other one (right) is silent. What is the reason fore this? Is it because I have a bad LRCLK? Is the source really mono? Is it because the source is left or right justified instead of i2s? Should the LRCLK be inverted?
Thanks.
Thanks.
If the signal set you wish to connect to the DIT4096 is the same as that shown in your post about the TC9231N then it is not I2S. Set the DIT4096 to Left Justified and the LRCLK and SCLK polarities accordingly and it will work.
rfbrw,
Thanks for your help. I gave it a try, and I still got one channel. Inverting the LRCLK just make the right channel come out of the left speaker. Not only did I change the FMT pins to Left Justified, but I changed the CLK pins to 256*Fs insatead of 384*Fs. Even changing that never made it output stereo, but I got audio with eaither clock selection when my crystal was really 256*Fs. The SCLK never needed any inversion. The DIT4096 schematic I used was:
There is some errata, pin 7 is not CLK0, but Vio. Pin 7 should be high. In this schematic, CLK0 and CLK1 are configured for 384*Fs, and FMT0 and FMT1 are configured for i2s. I changed these to Left Justified and 256*Fs. A quick link to the datasheet is here. If you see anything out of wack, please let me know. 🙂
Thanks.
Thanks.
rfbrw,
The actual source is the Nintendo Gamecube. I know it's stereo because I built the circuit using the TC9231N. Infact I just finished it today. It worked perfectly. I got the obselete TC9231N from parts.pioneerelectronics.com which sells it for $43. It's quite expensive just for one IC, but the part is obselete. It worked with stereo audio, no noise or glitches. The circuit worked fine. Here is a pic of the schematic:
I was quite amazed at how well the circuit worked. The waveforms that go into the TC9231N are:
You said it was Left justified which it looks to be. I knew I thought right. With the schematic in my pervious post, I changed the configuration to 256*Fs and Left Justified, but I still don't get stereo audio. I've looked up and down the datasheet and could not find anything. When I invert the LRCLK, I get the right channel out of the left speaker. (It could be the other way around, I forget how my DAC is wired as it is still on my workbench) This really stumps me because I had the same DIT4096 PCB working with the serial audio output of an XM radio with stereo audio, working perfectly. I must be missing something. 🙂
I'd go with this setting.
/AUDIO = 0
BLS = 0
BLSM = 0
CLK0 = 1
CLK1 = 0
COPY = 1
CSS = 0
/EMPH = 0
FMT0 = 0
FMT1 = 0
L = 1
MDAT = 0
MODE = 1
MONO = 0
M/S = 0
U = 0
V = 0
As the DIT4096 does not explicitly define the Audio formats for the hardware mode I'd used the definition for left justified given in the DIR1701 datasheet.That means only LRCK needs to be inverted.
/AUDIO = 0
BLS = 0
BLSM = 0
CLK0 = 1
CLK1 = 0
COPY = 1
CSS = 0
/EMPH = 0
FMT0 = 0
FMT1 = 0
L = 1
MDAT = 0
MODE = 1
MONO = 0
M/S = 0
U = 0
V = 0
- Digital Source
- Why only one channel?
