Why does the Tone Bender circuit even work at all?
Ah, interesting. So there is actually something behind this "fuzz". And I suppose it's rather important that the transistor be Germanium with it's 0.2 V drop since the range of the guitar signal is probably only ~2 Vpp (and that's when you're really banging on it). And since the input impedance of this circuit is probably low with no Re, I wonder if the coupling cap is charging up at all to bias Q1 as a function of signal power.
Many germanium transistors would pass a distorted signal without any bias at all. Even the ones with bias and DC feedback like the Vox Tonebender responded differently to different transistors. I still have one of the two transistor versions that I made in the late 60's. It used transistors borrowed from an old Sony radio. I put sockets in the board and swapped until I got the sound I wanted.
Also remember that most of the germanium transistors of the day had leakage currents around 1 mA, which also varied considerably with temperature. That's why the old fuzz boxes sound different when cold.
