perhaps Google would be a better person to ask.... ?
Hint: there are two modes: one is chemical and the other is mechanical.
Where does van der waslls fall? Not really either.
But van der Waals forces can be described in a physical picture.
Chemistry is just the physics of the valence electrons. 😀
Well, yes. Chemistry is just a branch of physics, philosophically speaking. And Van Der Waals forces are important in physical chemistry, so it all works out 😉
Don't say that when a real chemist is listening. Or be prepared to find a taster for your food and drinks... 😉
Glue can work in many different ways. Basically the glue has to form some sort of interaction with the two surfaces that are being joined. The interaction can be a covalent bond, or be an intermolecular force of some sort (hydrogen bonding, permanent dipole or van der Waals forces).
There is no division between biology/chemistry/physics. It's an artificial construct designed purely for the convenience of teaching in schools and universities. Once you actually do Science there are no boundaries...no hierarchy...except Chemistry is obviously the best!
A beautiful question.Simple question,
Why does glue stick things together? ......
Has anyone actually found anything that superglue can stick, other than your fingers ?
Yes,
It sticks the cap to the tube with a bond so strong you could lift the titanic with the same force required to release it..😀
M. Gregg
- Member Areas
- The Lounge
- Why does glue stick?
