Why does a A parallel quarter wave alignment cancel out every frequency after 860,(1720,2580,3440,4300…14620,…19780….end of horn resp…
Why does this parallel quarter wave alignment cancel out every frequency after 860,(1720,2580,3440,4300…14620,…19780….end of horn resp…(-990dB)? Those are sone really unique numbers… diameter of the sun, minutes/seconds in a day…or 48,96,192 hrs… procession of the equinox, (2580) Number of days in Leap yearsidereal(14620))
location if planets, etc… This things got it all…?
if it starts canceling at 860 which is 10 cm.
that’s the basis for the speed of light previously? Per Wikipediaz . And the 8/254 version of ‘pi’’ is 3.1496. This last spike in the response is exactly 149.6hz? Following one is at Mars to 236milion km/hz /uranium before fission? And filling in the three(1/4) harmonic but not at the 5(1/4 at that same location, And then the meteor bekt in all of that? Prior to the dip right where Jupiter is 475hz…
weird stuff that goes all the way back to offset driver to El Azteca driver position found in those. Which is essentially what’s being done on both sides of this in the first segment of each.
