Is the only reason because they're expected to cover a wide range of frequencies (i.e. breakup must be smooth)?
They're just a tad behind the times... 🙂
http://www.partsexpress.com/pe/show...D=172756&gemail=1&CFID=25982&CFTOKEN=71664086
http://www.partsexpress.com/pe/show...D=172758&gemail=1&CFID=25982&CFTOKEN=71664086
Hemp and Aluminum cones.... & Neo... 🙂
Anyways, on 'Rock' CD's I like high effienciency drivers mixed with aluminum drivers for that guitar 'Growl' and aluminum 'Slam"... 🙂
The Selenium WPU 1507 QCF that I use in the Altec A7 cabinets is a quartz composite fiber. You can almost hit it with a hammer. When you rap your knuckles on it, it sounds like someone knocking on the door.
http://www.partsexpress.com/pe/pshowdetl.cfm?&PartNumber=264-425&DID=7
Well this thread could get interesting (akin to a religious war if we are not careful). Here is my guess.
Pro equipment is made for a market that doesn't tend so much to the latest fads. Professionals want proven materials and construction methods that provide durability, predictable performance, graceful overload characteristics and easy repair in the field. Apparently paper or coated paper cones with cloth accordian surrounds meet these requirements better than foam halfroll surrounds and whizbang kevlar or metal cones can. For example a rigid plastic cone might be very good for a narrow range woofer in a hi-fi speaker used in the controlled environment of the livingroom where temperatures are steady and excursion is seldom streatched to the limit. Now how would that driver do in a wideband system that is exposed to searing heat, freezing cold and frequent overloads. Maybe OK, maybe not. Current pro driver systems handle that environment very well.
As other approaches prove themselves over the long term I suspect you will see more of them if they provide a significant benefit in the performance parameters important to pro applications. For example I think we are already seeing some use of rubber roll surround for extreme low frequency drivers where that provides a significant benefit.
Just my guess.
mike
Just my guess.
mike
I own some JBL drivers (2206 and 2226) that were designed more than ten years ago and which are still available. They use paper-fibre composite cones like some expensive Scandinavian driver brand does.
AFAIK they used such cones before they were fasionable in the hi-fi area !
I think I don't have to mention that these JBL pro drivers are suitable for very high-quality reproduction.
Charles
Charles
paper fibre offers some inherent advantages that are difficult to replicate with other cone materials.
Stiffness to weight ratio.
Damping.
Variable thickness.
Price to size ratio.
Availability.
Glue-ability.
Damping.
Variable thickness.
Availability.
Glue-ability.
Very simple - efficiency from low density/mass.
Those pro drivers linked are much less efficient than paper cone drivers; I don't believe the Selenium's spec given its high Qe.
A few months ago I sat next to a speaker designer, and he said the biggest advantage of high tech materials is marketing appeal.
The diaphragms must be firm and light. Hence the conical form (firmness) and use of paper mass (lightness). It's extremely difficult to move something heavier at high acceleration.
Acceleration is proportional to square of frequency, so
ACCmax=Xmax*(Freq*2Pi)^2 — very high, where Xmax is a function of Frequency, of course.
Of the best subwoofer systems I've ever heard, most had paper cones. I don't know if the cause was the driver, or the implementation. Most of the systems where the bass was very good, I didn't even know they were paper cones. I only found out after the good listening experience. Lot's of variables with subs. Placement, room, driver, box, etc. I don't know what Velodyne uses in their Servo'd subs (paper/plastic) , but they work pretty well (for a small box, not screaming SPL). Has anybody done THD sweeps on paper vs. plastic? Maybe transient response?
just ran into this thread and thought i'd bump it...
When it comes to woofers I've always thought that paper sounds the most natural and balanced. And i wouldn't agree that it's the cheapest either, as i understand there is always consistency problems, hence, a lot of throwaways.
Of course, everyone will agree that every material has a signature sound, some 'high tech'(rigid, piston like) materials sound more alike than different from eachother (IMO). To me, metals reproduce the initial transients more accurately (bells, cymbals esp) and on some recordings is top notch but on a lot of other stuff is lifeless. But I listen to a wide variety of music and find the signature of paper to be the least offense and most 'musical', dare i say, of all!
Could this be because wood is a natural material which has been used to make instruments since the dawn of mankind and its acoustic properties are genetically rooted in us as pleasurable?
just some thoughts!
just some thoughts!
Having used Pro drivers in commercial systems I can tell you they are tough and deliver the efficiency that you won't find with the bargin subwoofers. The electrical parameters have a lot to do with it. Oh, forget about trying to repair in the field as it isn't done in commercial applications. Maybe this has been tried in the DJ set. Just for S's & G's look up the specifications on a Altec,EV,or JBL driver and you will see the efficiency is there but so is the price.
You get what you pay for....
Heavy cones generally sound differently than paper. Yes, I am still a believer that larger drivers just don't sound as punchy as the 15's or 12's do.
Or maybe because wood is a natural material that is intended to be used as construction material right from the start. It is not just used by humans as such it IS a very sophisticated construction material !
Charles
Regarding the material sound:
in the german HiFi-Forum (DIY area) we developed a theory about this issue.
This picture http://img339.imageshack.us/my.php?image=csdk1k3km2.png shows an overlay of two waterfall plots, the red one the fundamental wave, the green one the 3rd harmonic distortion raised 40dB. The speaker is an ALR Jordan Entry2M, a 2-way with aluminium woofer and fabric dome. The measurement was quasi-anechoic, SPL approximately 90dB.
The woofer has a cone resonance at 5kHz, leading to a high K3 (less than 40dB below K1 => >1%) at 1.6kHz, even with a crossover which contains a notch filter at 5kHz. This can be seen in every HD-measurements, and every cone material which causes a resonance has this issue.
The difference between metal and other (soft) materials is that the metal cone resonance decays very slow, and so does the K3 - but at 1/3 of the real resonance.
After two periods (look at the y axis, it is in periods, not in milliseconds), K1 has decayed down to -25dB, where K3 is still at -10dB. This means, after a short time K3 is not -40dB but -25dB below K1.
Out theory is that this is audible. We suspect the same slow decay for IMD products, but until now I have not measured it (getting an impulse response of IMD products is quite tricky).
You do not need to measure the decay of K3, you can also predict its behaviour with a standard CSD an HD measurement. If you see a CSD with a slow decaying resonance and a HD peak, you can be sure that this driver will sound like a bicycle bell.
Greets
Baseballbatboy
Greets
Baseballbatboy
Charles
Charles,
we might be getting somewhere, if from different angles. Our senses are, after all, highly sophisticated survival instruments evolution has refined over millions of years and hardwired into our brains - only, spoiled as we are, when our senses try to signal us "this sounds/tastes/looks/feels unfamiliar and might be dangerous" we dont recognise it as a warning, we just don't like it.
Now compare the bandwidths HiFi vs. PA drivers have to cover. In HiFi a 12" is bass only, while in PA it's a midrange - little wonder the resonance spectrum of a "boutique" cone makes you want to
OK, just my two cents. As usual, it's rather a gut feeling than a scientifically solid theory.
Pit
I was aware of the "exagerating" of the harmonics due to resonant peaks. I didn't think about the temporal behaviour of the distortion products so far. This is indeed an intersting view.
Another way of looking at the problem is that the motor of drivers with very hard cones has to be more linear than the motor of a paper-cone driver in order to have any advantage at all.
One just has to watch out not to use PA drivers too high. Most P.A. drivers only excel over Hi-Fi ones in home applications (in terms of dynamics and distortion) when they aren't used the same way as in a PA.
Charles
phase_accurate said:Another way of looking at the problem is that the motor of drivers with very hard cones has to be more linear than the motor of a paper-cone driver in order to have any advantage at all.
Yes, of course. These HD peaks are highly related to the linearity of the motor. If the driver's motor in that box wouldn't produce significant distortion at 1.6kHz there would be no problem. A positive example of this is the Visaton AL130 ( http://www.visaton.de/en/chassis_zubehoer/tiefmittelton/al130_8.html ). Look at the CSD plot on that page. There is a resonance with a very high Q, but the HD is below 0.3%@90dB at the expected frequencies (measurement taken by the german magazine Klang&Ton). There is a peak, but very low.
Greets
Baseballbatboy
BTW, in Germany we say K1, K2, K3, ... for the 1st (fundamental), 2nd, 3rd,... harmonic. Is this the right term in English? Or must I say something like HD1, HD2, ... I can remember that I have seen such notation.
- Live Sound
- PA Systems
- Why are the diaphragms of pro woofers always made of paper?
