I picked up this cable a few years back. Its clearly expensive id say but what make is it?
Lets see if anyone here has come across it before.
what makes them clearly expensive, other than perhaps the custom "banana" plugs
RiChArd the cable.
If you're hinting these are signal cables, take a closer look
They are very well made, the cable is heavy and looks to be silver plated although I cannot be sure.
it would just be interesting to identify if possible.
The connectors look identical to ones I got, for a buck fifty each, from a surplus store in Toronto.. Most of mine fell apart, ended up replacing all of them...
Yours holding up well?
Yip 🙂
I was hoping this cable could be identified, no doubt it is known to someone. No negative comments please as its a genuine enquiry to satisfy my curiosity.
much appreciated.
much appreciated.
I just have the one, I have considered chopping it to make two short runs. Where my tube amp is positioned they would be a bit short so other than to satisfy curiosity it might be a waste. Thought id try and ID the cable first. Its sat doing nothing but looks too well made to just dispose.
reconfiguring them could then raise the questions as to
- do all my connectors need to match,
- is there a "magic length" , and
- what type of solder "sounds best"
Genuine answer: they are just a pair of (apparently) well made cables, at least of good gauge and apparently good connectors (although at least one answer that thos connectors were poor quality).
If you like it, fine use it.
If you need another (I guess you do), get a similar gauge cable and a couple banana plugs (no, they don't ned to match these) and make it.
Cable is as generic a component as can be, brands certainly mean little or nothing, so worrying about them won't carry you far, not even here in DIY where some agonize over them.
I've owned enough high end equipment over the years to know once at a certain level cables do make a noticeable difference. I had five demo speaker cables once, two were similar and three colored the sound.
Prior to component upgrades cables id tried made little difference.
If you cant tell the difference then theres other limits to your system.
Do I believe some cables are worth thousands, no. But to someone where money is no object they will be.
The question was can the cable be identified and the answer seems to be no.
If you CAN tell a difference between cables there are limits to your system, like a badly designed cable itself (this is sometimes done on purpose) or very poor amplifier design leaving the product marginally stable and thus susceptible to cable capacitance and/or inductance.
The cable in question was not identified because anybody with a modicum of knowledge simply doesn't care about fancy cables.
Yes, above a certain price level and below a certain competence level. If cables make a noticeable difference then something is wrong. All good cables sound the same, as all they have to do is get a signal unmolested from A to B - a relatively trivial task for such an undemanding application as domestic audio. Bad cables (which tend to be either very cheap or very expensive) can affect the sound as they suffer from design or construction errors: poor screening, high resistance, high inductance or capacitance.el donkey said:I've owned enough high end equipment over the years to know once at a certain level cables do make a noticeable difference.
So you agree then, cables do make a difference 🙂
I wasn't starting a debate on cables, thats been well versed on many sides for 30 yrs or more.
I simply asked if anyone knew its maker.
No badly engineered cables can make a difference, correctly engineered cables do not....I always wonder why other areas of electronics don't have such discussions on cables like you find on audio based forums?
Because it's bull
- Member Areas
- The Lounge
- who can name this speaker cable?
