Hello, I have a problem that I thought that would never encounter. That is, part of the screen is way too bright. My friends and I were playing Halo yesterday, and the white flashes make it near impossible to see anything else on the screen with any clairity. Basically all of my whites are too bright. Snowy scenes in movies are also bad along with white background for windows on the computer, etc. Does anyone know of anyway to remidy this problem? Possibly I need a better screen instead of using my wall.... Mybe my contrast ratio isn't high enough for my light bulb, 250:1, 250w HQI, no reflector, split fresnel. My blacks are as balck as the wall not part of the screen, so that isn't a problem...
Any ideas?
Any ideas?
gamma
Sounds like your gamma/color temps are too high on your panel. Do you have an OSD that lets you pick color temps on your panel? If you are using your panel with a computer run the color profile manager and set the output to what looks best.
