What is the hole spacing for terminal blocks for use on a Tubelab SSE board?
Do most Tubelab SSE builders have a preferred terminal block part number and vendor?
If you mean the ones that are soldered to the board Phoenix Connections make them part no' s 1715022 and 1715035 they at 5mm spacing. I have seen alternatives on ebay etc but I dont know what power rating they are. Yo need 2 & 3 connectors for sse the numbers above cover both.
