Which Sub for my cab?
Hi!
I have a cab exactly like this one :
This sub would be only for HT and as you can see is Bass Reflex.
I'd like to chose a speaker that could suit this cab (about 80L) and that would be efficient with very low frequencies.
150$ would be great, 12"
Does someone have an idea?
Thx.
Download the freeware WinISD program and you can model about a hundred drivers from its data base, or enter the parameters of any other driver, and it will tell you ideal box configuration for that driver. When you find the one that is approximately equivalent to your box you'll have your driver. Be prepared to change the duct length, as the one you have may be too short to support a sub woofers requirement.
What you're basically asking is for someone else to do the same thing for you.
