Hello,
To make some tries with various DAC, I need software for PC to convert FLAC 24bit/192kHz to WAV. Most of software is limited to 24bit/96kHz. Do you know software which is able to do that?
Thanks for your help.
I recommend XRECODE. This software lets you convert any format into any other format.
Regards.
Paul
Regards.
Paul
Hi Sandor
Thanks for recommendation. XRECODE is able to convert FLAC 24bit/192kHz to WAV 24bit/192kHz. For WAV conversion, you can't manage bit width or frequency. Conversion keep same parameters as original.I recommend XRECODE. This software lets you convert any format into any other format.
Regards.
Paul
Hi theAnonymous1,
It is very easy to use.
Very good soft.
Well, dBpoweramp is able to convert FLAC 24bit/192kHz to WAV. You can adjust bit width and frequency (44.1, 48, 96, 192...).Have your tried dBpoweramp? I'm pretty sure it can do it, but I make no promises.
Very good soft.
Here is a nice guide to convert FLAC to 24bit/192kHz WAV or 24 bit/96kHz WAV
FLAC to WAV Converter: How to convert FLAC to WAV on Windows and Mac?
It's easy to convert FLAC 24/192kHz to WAV without quality loss today. Here is a tutorial to help you.
This guide applies to:
1. Convert FLAC to WAV, MP3, AAC, AC3, DTS, AU, AIFF, and etc;
2. Convert other audio formats to FLAC;
3. Extract audio from video files.
I like Xrecode II very much.
Convert flac to mp3, flac to wav, ape to mp3, cue to mp3, flac to alac, flac to m4a, flv to mp3 and more.
Gold Wave can do 24bit 192khz flac.
It's great and it's free.
- Elias
Yes,Goldwave is suitable.I recommend the Foorbar 2000 or to accomplish this!
As for me,the flac is not the one I'd like to store.The universal format for audio nowadays may be the "APE".Music tracks are all gotten into the whole "APE integration"
Yes,I recommend the Foorbar 2000 or to accomplish this!
Just for those who use Linux or *BSD... I thought I should mention:
That's all 🙂
Code:
cd <where/your/flac-music/is>
flac -d *flac
Regards.
Paul
Just used it to convert 100's of .APE's to flacs (Xrecode).
To split full-album FLAC's ... (cuesplitter)
http://www.medieval.it/cuesplitter-pc/menu-id-71.html
To add/remove album art or change FLAC tagging ... (mp3tag)
Mp3tag - the universal Tag Editor (ID3v2, MP4, OGG, FLAC, ...)
To test the finished conversions - "audiotester"
vuplayer.com
1400 full albums done with these softwares (so far).
Tested 192 to wav plus various other functions - flawless !
OS
.APE is private closed source codec. Flac is open source.
Compression seems to be comparable on both.
Just got rid of 100's of .APE's had to install a "monkey" player to hear
them natively. Winamp/foobar/WMP do the flac's (more universal).
Most of "what's out there" is in standard FLAC , as well.
OS
- Design & Build
- Software Tools
- Which software to convert FLAC 24/192kHz to WAV
