Which probes for a Tektronix 2235?
TheDriver said:
Any critical specifications I should be looking for? Also would used Tektronix probes be a good idea?
Hi Matt, you've got a good scope, if it is in a reasonable condition. On probes - you need to look for a compensation range (should include 20 pF as it is the input capacitance of 2235) and the bandwidth (should be at least 100 MHz) .
Cheers
Alex
grimberg said:
Here is one more option for you:
http://www.probemaster.com/shop/index.php?cPath=2_8_10
I have bought multimeter and oscilloscope probes from them. They have a toll-free number, speak fluent English, ship immediately and have a very responsive customer service.
The 4900 series looks promising as it offers a wide variety of tips. The only thing I can't figure out is if I should get the 150MHZ or 250MHz probes. The price difference is only a few dollars.
Can I use the 250MHz probes with the 2235 and just stay below the bandwidth limit of the 2235, 100MHz? I am thinking once I get a larger scope I wouldn't have to go buy another set of probes.
Thanks,
Matt
Hi Matt,
Take a look here -
http://www.reprise.com/host/tektronix/reference/voltage_probes.asp
A good all around probe would be a 10X, 100MHz for your 2235. You may want to take a look at the P6105 13pF. This would allow you to calibrate it to 20pF (it has a compensation adjusting range of 15-47pF) every time you hook it up. Doesn't have to be a Tek. I believe this is what x-pro and grimberg were advising.
Hope that's helpful
I have been doing researching the above suggestions and came across the Pomona 4550B. It is a X1/X10, 15/100 MHz probe with an input capacitance of 10.5pF and a compensation range of 10pF - 60pF.
Has anyone had any experience with Pomona or this scope? The probe cost about $57 and comes with a handfull of attachments.
