Which lens kit do I need for my 7" lilliput PJ?
No replys?
Maybe I need to elaborate a bit more!
I am after obtaining an image size of no more than 100" (80" at best)
As mentioned before using a 250w source and a lilliput 7" LCD panel.
I am looking to buy a kit from lumenlab but all of their PJ's are made using larger LCd panels
Anyone out there point me in the right direction??
well, as far as i know, in terms of high resolution and 16 by 9 ratio there is no other small lcd,
the next best thing is to get a 15 inch lcd monitor. now there are some 15.4inch 16 by 9 lcd monitors but not as easy to find as the regular 15.1 inch monitors.
Thanks for the info, i'm going to start pricing some up then!
With regards to fresnel lens, do I need two (Front & Back) or will one suffice?
I have seen a lot of peoples designs using two but some people seem to use one, enlighten me!
How do I work out how far my LCD needs to be to the lens? Or does it not matter?
everybody use 2 fresnels but some people use them unsplitted (mean stick together).
about the distance, if you have a long throw(more than 5m) the projection lens will be a distance from the lcd equal to the focal of the projection lens. If you have a shorter throw distance the lcd-lens distance will increase. just test the righ position to get a sharp image.
or calculate from 1/f=1/p +1/q
where
f is your projection lens focal
p is the lcd to projection lens distance
q the projection lens to screen distance.
q/p will give you the magnification of your system
size of your lcd times the magnification will give you the size of your projected image.
you are all set
Right, time to get down to some slightly more techincal drawings than my last set!
Trying to get my head around some easy CAD software but its not going to well!
I'll post my plans up when i'm done so people can have alook and comment and improve (hopefully!)
Seen as it's my day off i've gone into design mode! Below is my preliminary design, nothing is to scale but all the parts I think i need are there
Box is going to be constructed out of sheet metal, hopefully this will act as a huge heatsink and help out with the cooling
I've not included any cooling options on the plan as yet, i'm going to do that when all my measurments are good.
I am struggling to work out how far my LCD needs to be from my lens, according to my calculations it should be 7.85 inches away, am i right?
Does the distance between the light source and the mirror make any difference or can that be any length?
I'm trying to keep this PJ as small as possible so want all my measurments to be right from the beginning!
I need to know the following if someone could help......
  • Is my calculated distance between the lens and LCD correct (7.85 inches) 😕
  • In theory, would the design shown above work ie; am I missing anything apart from cooling? 😕
