Does anyone recognise this horn model - it is roughly 12-12,5" opening for a 1.4 inch driver.
Oneminde
Oneminde
It is claimed they are constant directivity. I didn't find measurements or anything about their range.
Yeah no its not that, it the horn model. 60 degree dispersion and and fairly large opening. It might be custom but I don't know .. is it ?
To help myself, it is a 1.4 inch throat 60° X 40° constant directivity horn with approximately 340*280mm opening
Nope, not that one, but thank's for competing ... he he
If the opening is square you get a 40/40 relation. The one I am looking for has a 60 degree vertical dispersion and 40 degree horizontal dispersion, so wider than taller
Oneminde
Oneminde
If you're Swedish as your profile alludes to?The one I am looking for has a 60 degree vertical dispersion and 40 degree horizontal dispersion, so wider than taller
Try Hifisentralen.no
Not commonly available.
On here try Ro808 or Kolbrek, they likely have some info.
- Which horn model is this?
