As above guys... looking for a full range driver, ~4" which can be used in a 3L sealed enclosure. Would like reasonable extension to around 100Hz if possible.
Currently looking at the jordan JX92S, anything else out there I should be looking at?
Thanks 🙂
Thanks 🙂
If you're looking at the Jordans, and you have the money, then buy them. There's nothing that comes close in this regard. Apart from Bandors, which were also designed by Ted Jordan -I believe Bandor is run by his ex-wife.
Best
Scott
Best
Scott
Running JX92S's in 3 litre sealed cabs on my system with my own custom sub (using another British driver - Shadow Works) and the results are stunning.
hi,
http://www.zaphaudio.com/audio-speaker18.html
may be difficult to get in the UK so checkout
http://www.madaboutsound.com/prod.asp?pname=DFR
The TB design info is here
http://www.zaphaudio.com/archives.html
🙂 /sreten.
🙂 /sreten.
