I'm interested in building this great cabinet...but would appreciate getting some ideas for best driver...assuming I cannot locate a vintage pair.
For example, would this 18-inch unit from US Speaker be worth considering? The write-up says it is suited for a horn.
http://www.usspeaker.com/faital pro 18HP1020-1.htm
Or the Radian -
http://www.radianaudio.com/index.ph...facturer_id=0&option=com_virtuemart&Itemid=40
Regards.
Andrew.
Or the Radian -
Regards.
Andrew.
I have no idea about proper specs fore Jensen Imperial
But regarding Faital the 18FH500 looks to be the one fore hifi
About the Radian, my guess is that Qts 0.5 is too high, but might be nice fore a closed box
Yammie 3882B
What about the Yammie 3882b ? i think b stands for balltearer, they are an absolute monster.
From the japanese PDF,
Fs 30Hz
Qts .1
vas 296 Litres
VC 100mm
a beautiful looking speaker, it is a shame to put them in a box.
I've got 6 of them, i will sell a pair of them.
Peter.
p.s it is a 15" driver 102dB 1 Watt according to the nips.
Fs 30Hz
Qts .1
vas 296 Litres
VC 100mm
Peter.
This one from Selenium is recommended for folded horns. Reasonably priced also.
http://www.parts-express.com/pe/showdetl.cfm?Partnumber=264-398
Cal...that woofer looks good.
Peter...I was thinking of the Jensen Imperial 'Build In'
This one -
http://www.dcaudiodiy.com/jensen_imperial/page_11.jpg
Normally, I build cabinets using CNC routing. I have a guy in the US who's requested a Jensen...but at 8/10 the size. He'll use them resting on their sides...and place HF horns on top.
But for me, I just want to trial one cabinet using ply to test the bass response. I'm doing this because I have someone inquiring about a bass horn because he's crackers on organ music. He lives/breaths that opening track from A Space Odyssey 2001 where the organ grumbles away at below 30Hz.
Happy to consider a pair of your drivers. Please PM me or email alt@creationaudio.com.au
Kind regards.
Andrew.
This one -
Kind regards.
Andrew.
As mentioned by Exurbia, Decware might be worth a "visit", fore info on this design 😉 Sounds like they have build lots of them, or should one stay clear of their Imperial versions? 🙄
Decware Imperials
I can vouch for the Decware Imperials, I built a pair of them for our old house. Using one of the Yammies and a P-Audio BM co-ax. They really do deliver what Steve promises with the design.
If we had room in our new house i'd definitely build another pair.
Peter.
I should add that the twin driver setup is truly scary, i had a pair of Altec 210's with the same driver compliment. No contest, the Decware killed em dead. Although when the 210's were cut in half they sounded a lot better.
Peter.
On Decware
I note some drivers fire in, and some face out.
If I'm only after a bass unit up to, say, 150Hz....which config should I opt for?
Andrew.
Andrew.
Re: Decware Imperials
Which coax? I have a pair of NIB 15CX38 still unopened from a Daniel special. What are they like?exurbia said:and a P-Audio BM co-ax.
the BM's are BM15CXA, they are sitting in my cupboard waiting for another box. The CXA is a magic speaker, i think it is due to the smaller coil in the bass unit, they go higher and don't sound chesty in the mids, unlike the old tinny tannoys. They love power, lotsawatts and very clean and earachingly loud.
An open baffle might be the way to go with these, with a nice dipole bass.
Peter.
Peter.
Just thought I'd share:
This weekend I installed a built-in version of the Jensen Imperial (design by Steve from Decware) in my customer's media room (10' x 30' x 30') and I'm loading it with the B and C 21SW152 21" subwoofer.
I added 10db parametric EQ at 20hz with a slow rolloff to 100hz. Sub crossover point is 200hz. Power is supplied by a QSC RMX 4550 in mono-bridge mode. This driver is rated at 4 ohms, which allows the amp's output to climb to somewhere around 2200 watts. Since the driver is designed to handle 2000 watts rms, it's a good match.
Sound quantity/quality is exceptional. I play with tapped horns and thought nothing could beat the performance you can get from them--I was wrong! The Jensen Imperial/B and C combo not only get down into the first octave, it does so with amazing snap and clarity. There are times you can feel the sonics literally push AND SUCK your chest. I've felt positive pressure before, but never negative pressure. It's weird and wonderful.
The driver cost $600.00, but is worth every penny.
Eventually, there will be two horns...OMG!
Go the Jensen....
I've moddled my GOTO bass horn on the Imperial....
AVHub - Hi-Fi - News Articles - Famous Jensen Imperial Horn Reborn
Andrew.
Andrew.
Go the Jensen....
Andrew.
So you're the guy that built that pretty thing. Nice work! How does she perform?
Very nice project, Andrew! Have you considered making the throat longer, ie., as per the Imperial?
Yes...but we have purposely contained the overall cabinet size. Ming Su (US GOTO rep) has done all the ncessary sims to get a good product, flat to 35Hz and -3dB @ 28Hz.
One day, I'd like to build the original Imperial though....
- Subwoofers
- Which driver for Jensen Imperial bass cab?
