Which DAC with PM-94
Hello,
I've just became a proud owner of Marantz PM-94 amplifier.
However, I'm not sure which DAC would be best to buy.
Any expert advice? What do you think of Arcam RDAC, Rega DAC, M-DAC, Music Fidelity, M1, DACMagic Plus?
One more thing. How can i prevent overheating on PM-94? Is it a good idea to install a fan?
Thanks.
This is Diyaudio. Once you've arrived here, you're obligated to build your own DAC. 😉
What amplifier you have is not really relevant. Just pick the DAC that costs what you're willing to spend, or preferrably build your own.
PM-94 runs hot, and most of them are dead by now. A fan would probably not help much, your amp will probably die anyway (depending on how much it has been used), but could be worth a shot. Fixing it is usually not that hard if you have some technical knowledge.
