What do you think about this setup for an Aleph power amplifier's internal wiring:
- Input signals: One single solid core wire of 21awg (0.4mm2).
- Output signals: Two solid wires of 19awg and 17awg (total 16awg, 1.7mm2).
Thanks and regard!
Thanks and regard!
I suggest you to use multi-wire because of the «skin effect». This phenomenon causes the electrical current to run on the surface of a conductor...so the best way to achieve maximal signal conductance is to multiply the wires and twist them to maximise the noise rejection.
I think skin-effect only happens at RF and not audio frequencies. That's why coaxial cables were invented for RF circuits. Twisting two different wires does give it ability to reject airborne noise.
According to the formulas, skin effect only begins to be important at RF frequencies. However, if you try, say, 10 ga. solid core (only--no other strands) as an interconnect on a decent system, I think you'll find that it does indeed make a difference at audio frequencies. This is a clear example of one of those "numbers don't tell the whole story" situations. Enough of those and you begin to look at audio and so-called "snake oil" upgrades in a different way. Some of them actually matter.
One of the things to remember regarding strands--if insulated--is that it increases the capacitance, which begins to tailor the frequency response. In a worst case scenario, it can cause oscillation and blow amplifiers (happened frequently back in the '70s). Moral of the story: There's a balance to be struck between the number of strands, their gauge, whether they're insulated or not, composition of the wire, composition of the insulation, etc.
Grey
Grey
