Which Amp for 4 Ohm SEAS Exotic Fullrange?
There are many other drivers I would also consider before those ones.
To answer your question, basically any Firstwatt design biased appropriately.
It will depend on your taste more than anything.
Thank you.
Amp-wise, I was thinking that a PP, for example, would be preferable, given the impedance.
What would you suggest as alternatives in the 8", decent Xmax, 94dB SPL+ sensitivity segment?
Audio nirvana classic 8" with ferrite magnet for boxed speaker. For open baffle the Alnico version or Ferrite version.
Fostex make some nice full range drivers.
Lowther Pm6a are good but not the best value for money.
You don't need push pull on a full range driver, the amp just needs to be biased appropriately.
An Aleph J type circuit biased around 2.6A instead of the standard 2A would be ok.
If you want push pull and already have a very nice preamp then probably F4.
Otherwise F6 or M2.
Otherwise F6 or M2.
My worry is that the AN will not hit 93 dB @ 100 Hz due to the very low Xmax (1 mm).
If the much cheaper FA22 is any indication then the SEAS Exotic should be really good. Like the FA22 they work nicely in a biggish sealed box.
My experience with current Audio Nirvana is limited to the 10” Ferrite and i’d easily choose FA22 over them. Lowthers are hard to get any bass out of, the Fostex F200A (or the ferrite version) are no longer available, the FE206 needs a horn and needs work, the FF225wk needs a tweeter, i have a pr but haven’t heard them yet.
The only downside of the SEAS Exotic — at least to me — is that they are quite pricey.
dave
No, I mean 5.1". I got the SD data from the manufacturer and did the math. I am interested in the actual, not the nominal diameter, as the latter isn't useful in any performance calculations. (The Exotic is about 6.6", 1.7x larger SD. I realized I jumped around on definition a little.)
Stay in tune if you are interested by active filters and equal for FR.
Papa is design new "toys": FIRST WATT WATT'S NEW
Kindest regards :happy1:
Always best to talk about nominal sizes, otherwise you start confusing people.
dave
dave
With more thought, I believe that the actual diameter is really the only sensible metric once one gets into a detailed analysis, as there can be rather big divergences between how the manufacturers rate their drivers.
For example, the MarkAudio Alpair 12P is described as an 8" driver yet has an effective diameter of only 5 3/8". The 8" SEAS is more than 50% larger in area.
Which spec is more confusing?
