I got the following drivers and am trying to design a speaker.
ScanSpeak: 21W8552 + D2905-930000. The only problem is , I don't really know what to do with all the numbers in the specs 🙁
With some help I got to the following specs for a box:
35L, Fb-45Hz Port: d-76mm L-120mm
Can anybody suggest a x-over point and circuit for me please, and also if neccesary a better box / port for this driver.
Attached is all driver specs I got.
Thanx for any help.
Thanx for any help.
You have a really nasty peak there right around 3500.
I would suggest a notch filter at 3500, which might be all you need, the top end of the woofer rolling off after that.
I would cross the tweeter over at 2k.
I haven't really done any notch filters on my speakers, so I might not be the one to give advice here, but I would certainly consider the approach.
Anyone out there with experience with or with a program that does notch filters?
