Building up my Legato v2.0 tonight I put in three of the P-channel MOSFETs backwards. Doh! They did not come out intact. The other nine are correctly placed.
Anyone know where I can get a few BS250KL-TR1-E3? They are coming up as NLA...
BK
BK
Find BS250KL-TR1-E3 Stock and Compare Prices Across the Most Reputable Distributors in the Industry.
http://octopart.com/partsearch#search/requestData&q=BS250KL-TR1-E3
A note.... I read that the part is no longer manufactured and thus NLA.
If TPA can't supply, there are firms that stockpile NLA parts and you need to put in an RFQ for them ( request for quote) but most if not all have a minimum dollar requirement ranging from $50 to $250 dollars for a minimum order...
Good luck
JD
Good luck
JD
Thanks for those links - I put in some RFQs and will see what happens.
I'm hoping TPA or some kind soul has a few left over!
Here's the current status:
I'm going the check in a few minutes. If I don't have them, I can set you up with a set of the replacements (TP0604).
Thank you, Brian! Please let me know if you come up with any BS250.
On a related note, are the TP0604 a drop in deal if inserted backwards to compensate for the different pinout? Would I need to replace all 12 BS250 with TP0604?
BK
Yes, they just go in backwards. You would need to replace all of them as they are a different part.
If Russ can't supply, I think I have some.
Let me know if you are still in need & I'll check.
Greg in Mississippi
Greg in Mississippi
Thanks for the offers to help out! The support among the TP customers is wonderful. Brian fixed me up with a set of TP0604 and shipped today. Plan is to completley change over my Legato v2.0 to those devices.
Now if anyone has any tips for effectivley clearing the PCB through-holes of solder after removal of the previous components I'm all ears!
BK
BK
Yeah, that's kind of a pain without good equipment. I get to cheat and use a nice Pace MBT 201 station at work.
I've never used one, but some folks use something like this.. Edsyn - EDSYN DS017 - "The Original" Deluxe SOLDAPULLT I guess I would stand the board on edge, by clamping in a Pana-vise or something, put my soldering tip on the pad, and suck the solder through the opposite side with that doohicky. Be sure to use a little flux.
BK
Cocktail stick?
It's actually pretty easy...
Solder wick: 1811-5F: TECH SPRAY: Test, Tools & Supplies
or a desoldering pump:
08-033: JAMECO VALUEPRO: Test, Tools & Supplies
For the wick, hold it on the hole with your soldering iron and it will suck the solder out.
For the pump, heat the hole from one side and suck the solder out from the other side.
If you buy either of these, they will come in handy in the future. I promise. I use both all the time. The solder wick is helpful for SMD work as well.
I used solder wick and pump and copious liquid flux to initially try and salvage the backwards BS250. Didn't like how that was going, and didn't want to compromise the board, so I cut the individual leads and removed them one by one. Afterwards a few holes didn't want to fully clear with wick or pump, so I set things aside to get some expert tips. Will try the pump from the opposite side of the iron with the board held vertically in a panavise - that's a good idea. Have also heard I can stick a long cut lead through the molten solder to clear holes (cocktail stick?). Desoldering always gets me very nervous and uptight!
BK
BK
BK
Yes - that's what I do anyway. Heat, poke the stick gently through, then keep twiddling it slightly while any remaining solder cools. Less likely to get stuck than a cut lead. Tends to leave a bit of solder around the rims of the hole but at least you have a hole and that sorts itself out when you apply heat to solder in the new component.
When there is solder stuck in the hole, the problem is often that it needs flux. I find the best way to deal with this is (a little counter-intuitive) to add some more solder, then suck it all out in one go (or wick it out).
Another thing I always do, add flux to the wick every time I use it. I have a no-clean flux pen that it my constant soldering companion.
Mission accomplished! Huge thanks to Brian for setting me up with a set of TP0604, which arrived today ahead of schedule.
The solder pump literally worked like magic. I cut the BS250 off, clamped the board vertically, and heated from one side/sucked from the other. In almost every case the cut lead got sucked out with the solder and I was left with a perfect hole. I made sure to use a freshly tinned iron with a small amount of solder on it for each position, plus some flux on the pads. Really could not have been easier. I'm kicking myself for initially trying to salvage the incorrectly installed BS250 and nearly pulling my hair out.
Populated board below - still needs a good cleaning.
BK
BK
Sounds good, glad it worked out. I've replaced literally thousands of parts over the years being in the electronics industry. When you're not trying to save the part, and normally you aren't, it works best just to cut the part out and remove the legs one by one with tweezers, then desolder the holes. The whole purpose being to keep the pcb in perfect shape.
It took me nearly a year to wrap up, but the Legato surgery was a success and it's now making good music. Thanks again for the help.
BK
BK
- More Vendors...
- Twisted Pear
- where to get more BS250KL for Legato v2?
