Hi all
I´m looking for 8-10 8" high excursion sub´s.
i´m planing to use them in my car in a sealed cabinet. It will give the WOW efekt 😀 and i hope i can make it sound nice
But every time i find a good wofer it is in US. And it will cost my far to must in shipping and tax´s.
Thank you for helping me
will HI-VI D8G 8" WOOFER from partexpress be a good choice ? and where to buy in EU ?
ported box would be WAY better.... you can get the "wow" effect with two 8's in a ported box... lol that can be quite easily heard form half a block away..... 😀
wingman said:I know but i like the sound af seald better and i can have the space for more woffers !
yes, and you'll need more woofer to even get the same dB output at lower frequencies.... and more power.. 😛
it will also depend very much on the woofers as to if they are really suited to a sealed box....
my friend has two of these:
the box was sealed before he had time to go buy a port, the bass was there, BUT IT SUCKED!!! 90litre sealed, yea, too large really..... once it was ported, the bass is amazing for a couple of cheap 8inch subs... I still can't believe it actually... lol
I know !
Do you know where to buy the sub in EU or what the name for the sub is ?
wingman said:
I know !
the brand is Venom... as to where you can get them other that Australia... wouldn't have a clue... they are pretty darn cheap though 😀 hehe
if you buy: (Australia Dollars)
1-4 they are $39.95 each
5-9 they are $35.90 each
10+ they are $31.90 each 😀
which is.....
$US27.86
$US25.04
and
$US22.25
🙂 lol I'll go away now.. 😛
Hi Wingman
You know 8 inch units are better for tight quick bass, but you will need 12 if you want to make your life eaay, to get that big bass wave! I used 8's but the box size is to large and now adays 12 can run in 30 to 40 liters, I noticed you said you like tight bass, then a sealed box is better, what do you think of this Blob!
Wingman, start by contacting
www.frequence.dk
www.q-sound.dk
www.danskaudioteknik.dk
and see what they have available.
Oh, if it were me, I would buy as many Peerless 10" or 12" XLS drivers as I could afford instead
/U.
www.frequence.dk
www.q-sound.dk
/U.
Thanks for reply !
If i can´t get any 8" in a sealed box that will play low. then i need 4 10" in sealed box that will do it.
I do not want XLS 10".
Wingman, dont you like scan speak? they can play quite low,
The peerless is a little to round sounding to me, its not a tight sound, in other words, i may be wrong, but that's just me.
I think Vifa have a new woofer out that could be used for in car.
If you want to see some interesting subwoofers, look here
www.shadowworks.co.uk
Just let me know what you think thats all.
The Peerless SLS8 does look quite good in 40l sealed.
Found it whilst looking for a mate to my Tangband W3-871S.
Paradise_Ice
Scan speak is ok ! But peerless is not ! (i know that it is d-s-t that make scan speak and peerless)
It look nice BUT i can´t find any 10"
joensd said:The Peerless SLS8 does look quite good in 40l sealed.
i´ll look in to that. But 40L
You didn´t mention that you need your boot otherwise.😉
Maybe you should do a research on "URPS" (under resonance principle subwoofer).
Here you use a sub-driver in a much too small cabinet.
I don´t know much about it except that it eats piles of watts.
How about these?
http://www.mamut.com/homepages/Norway/1/18/dynabel/subdet342.htm
(download the brochure from the link at the bottom. Enclosure recommendations on one of the last pages)
/U.
/U.
Nisbeth said:How about these?
/U.
Thanks ! The 8" goes in 11L !
NICE
You could also take two cheaper drivers and make a compound system where the cabinet size will halve in contrast with having one driver.
joensd said:You could also take two cheaper drivers and make a compound system where the cabinet size will halve in contrast with having one driver.
Then i need 16 8"
Have you ever used any Dyna Bel woofers,
We use the same designs.
I am interested to see if you like them at all?
Paradise_Ice said:Have you ever used any Dyna Bel woofers,
I like them alot ! BRONZE® i the first Bronze colour sub i have seen COOL ! But where are the 10" sub ?
i have never used Dyna Bel subs
- Subwoofers
- where to buy 8" high excursion sub in EU ?
