I make amp 40w tda1560q.
It use external 2 capacitors 2200uF to help make high voltage.
I use circuit in its datasheet.
Its has sound of distortion all the time, no music out.
When i short circuit the C 2200uF on the left, the music comeout.
I think one of the circuit in the ic that make voltage is broken.
I never make a risk that ic can broken.
Does the ic broken?
Does the ic broken?
Can you show us a circuit of exactly what you have built.
It sounds like you have the cap in series with the rail which would be wrong!
Nuuk said:Can you show us a circuit of exactly what you have built.
No, Nuuk, it's ok.
These are car-audio BTL "class-H" chips, they have a pair of caps between two pins each for lifting the voltage after a certain power output, when the class-H circuit kicks in.
Otherwise it would not be possible to have such a power with only a single 12v battery.
This chip is similar to the TDA1562, but with less power.
I don't know what the problem can be, though...
Maby a faulty chip, but they are not cheap... the TDA1562 costs ~15€ around here.
I see Carlos. I only have a bicycle so don't have such problems! 😀
Nuuk said:I see Carlos. I only have a bicycle so don't have such problems! 😀
Hey, I bet you don't have a system on your bike...
Yet. 😉
I have no money to buy new ic yet. must wait to next month.
the 1562q is 50% more expensive than 1560q here.
so I buy 1560 to try.
jinkuchi said:I make amp 40w tda1560q.
Hi jinkuchi
Is the pin 17 of the IC connected to ground?
If not , connect it to ground...
Jorge
- Chip Amps
- when i short circuit the C the music comeout. Does the ic broken?
