Whats the deal on AC line filters.....
As i see it i have thre options...
1; buy and IEC plug with integrated filter
2; John rich filter....hard to get parts
3; Make a totaly overkilled filter with 3pc of 1,7mH 0,02R coils for each phase and so on...
BTW should i filter the Ground wire aswell?
any suggestions the filter will be built in to the amp the rest of the PS will be a 9Kg 900VA toroid wit approx 0,2F of capasitance after...(yes i got a big fat softstart circuit...)
/micke
I'm using a Schaffner FN282-6 IEC plug with integrated filter, fuse-holders and power switch. It works great. But last week I blew up the built in power switch, so now I must buy a softstart circuit.
Elfa sells the "FN282-6", art.nr. 69-673-76.
What softstart circuit are you using? I'm thinking of buying the lcaudio.dk. digital softstart.
/Freddie
i use a cap to lover the AC line voltage...(throug its reactance...dosn´t produce heat...as a resistor would..) the power is feed to a cap and when it is full the power goes to the relay in the meantime ...a couple of secounds i let the power go through a 100R 20W resistor..
I have schaffner on my cd and preamp as of now but im thinking of something more extreme....
/micke
that integrated schaffner was a bit pricey....i need 2 u se...
Why would you want a IC controlled soft start....completely unnecisarry...(IMHO)....but hey its your monney...
BTW i will have my aleph boxes professionaly made..=) rockon.....CNC laser machines.....=)
/micke
I typically use Corcom filters in my projects. They seem to work well, though admittedly I've not tried many other options. Digikey carries a nice selection of these, both separate filters, and filters with IEC plugs.
