What kind of RESISTOR is this???
Can someone help me identify this type of resistor? It looks like a ceramic power resistor...value is 180 Ohms / 2 watts (2WJ). I am trying to repair and old Mitsubishi receiver. Upon inspection of the PCB, I found 2 of these resistors on the board in the power amplifier section that appeared to be burned out so I removed them, but I want to replace them with the proper type/value ....Thanks in advance!
Pic @:
Youve measured thier values or just noticed the brown color?
If you havnt measured the value, do so, becuase they still might be ok... resistors going brown from heat isnt a problem.
If you still want to replace them, try using 5W resistors instead, they will be easier to find.
<<< You've measured thier values or just noticed the brown color?
If you havnt measured the value, do so, becuase they still might be ok... resistors going brown from heat isnt a problem.>>>
Thanks for the reply,
No I haven't measured them (can't find my dang multi-meter) but the fact that the inside top of the receiver cover just above them is black from the smoke emmitted from them is a good assumption that they may be burned out. You are right, discolouration from heat is normal...
Again, everything else on the board seems fine except these 2 resistors.
Can you tell me what type (cerramic, metal film, carbon, etc...) they are?
But why would you care? Trying to preserve the aural flavour of a seventies jap receiver? I sincerely doubt it will be possible to distinguish them. Get a cheap metal film replacement but only after finding the 'dang multi-meter'. You'll be very lucky if those resistors are the only problem.
It got pushed, rather than jumped...
What model is it? And what's the problem?
I probably worked for this [crap?] company during the period this was produced...
The long leads mean that this resistor was meant to get hot. It should have been spaced away from the PCB, probably using fibreglass sleeving.
The fact that there are black marks on the lid above these, does not necessarily indicate smoke. Hot components cause air convection. This convected air contains dust and grease particles that are deposited.
I expect this kit has worked reliably for 20+ years. Plenty of time for air flow..
The resistor is a metal film 180 ohms 2w 5%, but I agree it is probably not faulty.
Re: It got pushed, rather than jumped...
Yes, they were spaced away from the PCB, but lacked the fiberglass sleeving...Thanks for the tip on the air convection, now that I look, the space above the power transformer is a little dark too, but it does not appear damaged (I'll have to check it). Its a Mitsubishi receiver model # DA-U109 100WPC (yeah right) that only produces sound from the left channel. Just tinkering to see if I can fix it. I have to check the preamp section as well to see if the issue isn't with it. Once I find my multi-meter I can verify the integrity of these parts. I hope it IS the resistors so it'll be an easy fix...
Thanks again dhaen!
If the resistors have gone, then its a near certain bet that something else much more serious has happened to cause them to go. Resistors are the most passive component and very rugged (as compared to transistors which will go at the slightest provocation.)
Shoog
DA-U109
I didn't see that model in Europe, but the DA-U's were not high quality units (performance wise), though the build was good.
Shoog is certainly right. probably a semiconductor device in the output stage failed, and will have taken others with it 🙁 Around this time was the changeover from discrete component output stages to hybrid IC (usually Sanken). I suspect yours has the former.
The bottom line is: You'll need an expert to fix it, and it probably doesn't merit the labour cost....sorry.
Re: DA-U109
Yeah, its a peice of crap no doubt...again, I was just tinkering. I guess I can strip it down and sell the comopnents? Those STK4042 power amps aren't cheap... and the power transformer may still be good enough for someone with a DIY project needing one....where theirs an ebay, there's a way....
Thanks.
BTW: My actual system consists of:
Adcom GFA-555II x 2 (running as 600W monoblocks)
Ming-Da MC-7R valve preamp
NAD C540 CD player
Mint Dahlquist DQ-10's (upgraded XO,s and wiring, binding posts, Peizo replaced with True Ribbon driver)
ZU cable WAX speaker cables
ZU cable Gede interconn's
Looking to add 2 x 12" subs for a nice bass coupling effect: Since DQ's are somewhat bass shy. I'm not into the low end really, but it is nice to hear. Also looking to upgrade my NAD C-540 to a Jolida JD-100....
It looks like a Metal Oxide, possible fusible, you know the value and wattage, the J usually means 5% tolerance.
The only Marking that looks like a brand name is an FD or FO, I have a resistor in front of me of the same make, value, wattage and Tolerance, spookey
Hope this helps
James
